the sled is a 11 pro 800 turbo. i just rebuilt the motor because it had 90psi on both cylinders. i put new wisecos and rings in and when i checked compression it was still 90. i measured the bore, ring gap, and everything was within spec. all new gaskets, cleaned up the exhaust valves, and put new reeds in. ive tried two different gauges and get the same reading. i deglazed the cylinders with a 320 grit hone brush. im lost as to where to look now. any ideas? do the rings need to seat?
