There has always been much debate about how long the cross hatch that the honing process lasts in a cylinder. The cross hatch is what provides the abraded surface for the rings to seat. Some say it's a matter of minutes. Some say hours. Either way, with modern metallurgy and engine assembly techniques, the crosshatch doesn't last long and doesn't need to. As long as there is sufficient friction available. With 'syn oil, it is very slick which provides a great friction barrier on the cylinder walls. Good for normal operation. Bad for ring seating considering the crosshatch doesn't last long, and that is where the argument stands, how long does the crosshatch last. You can pull a motor down with 8000 miles on it and still see a lot of evidence of crosshatch, but none of it is beneficial to ring seating. It is all irregularities imbedded in the cylinder walls. What you are looking for is the raised portion of the crosshatch to bed the rings, for which supports the argument that the crosshatch is very limited in use for break in purposes. If you use "dino" oil during break in, it will ensure enough friction is provided to seat the rings in during the very limited time the crosshatch is of any value, which explains the theory of limited full throttle input. This technique puts more inward and outward pressure on the rings which will enhance the abrading process, but developed excessive heat on the rings and ring lands. So by limiting full throttle input, you can control the heat, but quicken the process which is not a bad thing at all. Personally I only break in my engines using pure dino oil in the injection tank (semi Syn is fine), and a 100-1 ratio of dino oil in the tank. The only reason for oil in the tank is to save the motor if there is any issues with the oiling system. Sorry for the long post. Jay.,,,,,,,Just sayin. BTW, the only disadvantage to using dino oil in a stock trail motor is excessive carbon buildup on the power valves. So when you switch over to 'syn oil, which 2 tanks is plenty, pull and clean the valves with brown scotchbrite and WD-40. I actually use Citgo Sea and Snow semi-syn on all my sleds with no issues at all and it's cheap,,,if you can find it.
