Apex Big HP
We would like to see you sleeve with Hurricane setup because of flanges and close deck cyl.
We can get that done for big HP motors.
Also we are working on new stage 3 Apex intercoolers and here is picture of core.
www.powderlites.com
Apex new turbo kits
Stage I 300 HP
This kit comes with GT2860RS Garrett turbo with ported waste gate, ceramic coated housing and 2” double divorced down pipe for great efficiency.
We at POWDER LITES are always improving our products so your ride is the best it can be.
Intercoolers have changed a little now with better velocity stacks; cores have no side plates or fins so we get extra tubes.
Charge air coming into front tank is good for high boost without having uneven flow to each cyl.
Air box is sized to engine and tubes in the intercooler cores straighten out air to air box for low pressure drop.
We never put air into front tank with elbow so charge air is blowing across tubes causing siphoning on first few tubes and high pressure on end tubes with low efficiency and uneven charge to each cyl.
Deeper core tubes are now standard on all intercoolers plus a new core for stage 3 Apex good for over 400 HP
All turbo kits now come with Rapid bike 3 so you have the best control over EFI / Ign timing plus bonus of easy upgrading maps or tuning for custom setups.
1- RB3 can raise RPM limiter
2- Run 2 maps that can be switched manual or with a boost switch etc.
3- 2 maps give you race or pump gas maps at different boost levels.
4- Stutter button for drag racing at what ever RPM you want.
5- Advance timing or retard at any RPM for throttle response and using higher boost levels and stock compression ratio’s.
6- Email maps or share with your buddies without sending box back to reprogram.
7- Blue Bike/Tooth so you can change maps or fine tune with smart cell phones, palmtop, laptop etc using Windows Mobile
8- Can be used on stock motors and then add map sensor to run on boosted engines.
Apex stage II 350 HP
Garrett GT2871 with machined intake, ported waste gate, and ceramic coated rated at over 450 HP
2.25”double down pipe with divorced waste gate.
Intercooler is Longer and coated to help in cooling charge air.
Newer 4 into 2 then into 1 header for better throttle response and HP.
Apex Stage III 400 HP and up
Larger intercooler cores with deeper tubes 2.81 “
Coated with heat dissipating coating
Larger injectors rated for over 500 HP
Parts for your engine build
Chromoly H-Beams Rods
JE Pistons
Heavy duty head bolts Apex/RX1 Needs head work to use.
Camshafts for Turbo
Springs for turbo cams
Block sleeving and oring kit with flanges to close deck block
Bore bore kits
We also have parts like header flanges, Turbo flanges.
Everything from Butterfly clamps to welded stainless 9mm thin hose clamps that won’t strip or come loose.
3” Air filters and snowdust covers
AEM Wideband gauges
Turbos in stock for most applications
Don’t see what your looking for just give us a call.
