Physics must be in lala land
Ok, blind leading the blind here, sorry I mentioned anything lol. I agree on the HP loss and the need for higher boost pressure to compensate for the oxygen loss from elevation. You guys are confusing everything that happens AFTER the compressor though. Have fun in lala land fellas.
I don't think this is the thread to debate this, since the poor guy just wanted to know about what fuel to run. But since we were described as being in lala land I thought I should respectfully state something in defense.
Taken word for word from my physics 101 book in college: "It is important to note that pressure gauges register the pressure above and beyond atmospheric pressure. This is called GAUGE PRESSURE. Thus, to get the ABSOLUTE PRESSURE, P, we must add the atmospheric pressure, PA, to the gauge pressure, PG: P=PA+PG. If a tire gauge registers 220 kPa, the absolute pressure within the tire is 220 kPa+ 101 kPa (atompheric pressure)=321 kPa, equivalent to about 3.2 atm (2.2atm guage pressure)."
I agree, the concept is a little difficult. It seems that if my tire pressure gauge reads 40psi in my tire at sea level and then 40psi at 10,000ft, the tire would have the same pressure in it at both elevations, 40psi! Wrong, 40psi is giving you gauge pressure, you will have effectively less absolute pressure in your tires at 10,000ft than at sea level even though the gauge reads 40psi at both places... The physics book translates this to scuba diving as well. Diving to the same depth at elevation will result in the diver experiencing less absolute pressure than at sea level. The same thing goes for a turbo. The gauge reading 13 pounds of boost in the charge tube is meaning 13 pounds of boost on top of atmospheric pressure. Since atmospheric pressure goes down with increase in elevation, overall your turbo has "less absolute boost" as you go up in elevation, meaning less absolute power as well.
The turbo is a compressor, it will compress air the charge tube to the set level, say 13psi. This 13psi is 13psi gauge pressure. Therefore compact air going into your cylinder is 13psi plus atmospheric pressure, which again, goes down with elevation increase.
Oh but you might be thinking, "doesn't the waste gate start releasing air after an absolute pressure in the charge tube? Therefore it doesn't matter if you are at elevation or not because the waste gate is going to release after it has the set absolute pressure in their regardless of atmospheric pressure. So if I set it to 15psi, it will be that specific pressure no matter what regardless of elevation because it is a closed system." Thinking that, however, would be wrong because you only balanced one side of the equation. The turbo compressor system isn't really closed. The waste gate is going to release after a specific pressure in the charge tube, but where is that pressure going? Outside the system! Therefore you have atmospheric pressure pushing back on the system. Remember Newton's laws? For every action there is an equal and opposite reaction. Thus, when that waste gate released after building 15psi, that 15psi is actually gauge pressure, because atmospheric pressure was inside the charge tube as well as outside! Lowering atmospheric pressure with altitude is going to lower both sides of the equation, meaning that 15psi gauge reading is gauge pressure. Your absolute pressure and effective pressure in those sweet arctic cat pistons is going down as a result of decreased atmospheric pressure.
One last way to think about it. Say you had a beautiful orange and white 2012 proclimb with one of those sweet new standalone ECU PUSH turbos running 15 pounds of boost at 6,000ft elevation. However, you were a little man that could crawl into your charge tube and held a barometer. What would the barometer read? 15psi? Nope, it would read 26.4! Why? Because atmospheric pressure is 11.4 at 6,000ft! Now you crawl out of your charge tube with the barometer and stand on the sled, now it reads 11.4. The compressor system is sucking air outside of the system and then spitting it out the other side of the system, exposing itself to the pressure outside of the compressor system, atmospheric pressure...
Just because a turbo causes many magical things when it comes to snowmobiles, doesn't mean it can defy physics...
