If you do a search you will find a lot of discussion on this. The general consensus on here is the 046 is the better belt, because the 060 has a tendency to explode with no warning. An 046 is a harder compound and will slip more, but most have found it lasts longer and gives lots of warning when it goes bad. As a general rule an 046 will raise your shift RPM about 200 rpms.
