Wheres the screw hole for the belt???
I must be retarded but I can't seem to find the damn hole (never had that problem before :D...) Anyway, Ive done it before and can't find it. Have a pic of it? Thanks guys, this will never happen again....:rolleyes:
Yes, this is to take the belt off, I need to clean the clutches... THANKS!
look at where your secondary clutch bolts on the shaft. Within about a 2" radius of that blot in the center of your clutch you should find a hole 1/4" in diameter. That would be it!
Im guessing the secondary clutch is the one that moves the track. And on that is one big center bolt and I believe 3 small bolts surounding that, and between two of the smaller bolts there is a hole there, the adjuster fits in there but it feels like its the wrong hole. When I first looked at it I don't think the hole was threaded but after a few turns of the tool I think I was threading it.(Thats not right...?) I've looked everywhere and thats the only hole I can find, but when I turn it in that one it feels way to tight to be right, and nothing happens, I think ive gone 1/4" or so in... Wrong hole??? :) A picture would be nice but i'll probly have to look again.
That's the right hole. Maybe you need a a little lube.
Ya, it was kina crusty and it takes some effort to keep it goin, havn't gone any further though, will in a bit... Thanks guys, just wanted to be sure I wasn't in the wrong hole... We all know what can happen if we put something in the wrong hole... :) Money outa yer pocket however ya look at it... :):):) Thanks again.
Well, I twisted it in till the clutch started to spread apart. Got it about 1/4-1/2" spread and it became so hard to turn the tool I thought I would brake it... What the h*ll... Is this normal??? Little WD40? Ive never replaced this belt before, when we did we had to cut off the old one after it rolled cause we lost our tools and had to tow it out...
Your secondary probably needs cleaned. You can strip the threads very easily in there with that tool. Clean your clutch are find some one that will.
