Where to put my Extroverts
winter brew
4,332
LakeTapps, Wa.
Asuming the drivers were in the correct loaction, I mark the center of the shaft. Then the measurements will depend on what drivers are being used.
Look at where the drivers need to be on the track and make measurements on the track....place drivers appropriately from the center mark. Generally you want the extro's to be biased to the inside of the windows so the track can't wander and hit the tunnel sides.
eddy
1,095
261
83
67
Sammamish WA
Driver location
The factory shop manual has very specific dimensions for driver placement on the shaft. Following those will get you the right position. When changing to extroverts you line up the critical dimension for the center two stock drivers. Watch for the relief notch (for the track clips) to be to the outside and the phasing between the two to be consistent with the factory marking.
G
Nov 4, 2010
119
22
18
drivers
I don't know if you already purchased drivers but if not I have a driveshaft and drivers for sale that was setup for a 16" wide camoplast track. If you have drivers already I can get you the measurements from mine this weekend.
