Where to hook 12v to power up system?
J
jkjasperson
Installing a PC5 up to a 2013 pro, where can I hook a 12v battery up to power the system and get the TPS settings ?
On my 2011 there is a connector above the LF shock tower. It is labled ECM, two wire connector.. Do not confuse it with the DC power connector next to it. They both look similar,.
Can't you just start the sled and get the TPS settings while it is running? I thought the PC5 allowed you to do that?
Yes , but you will have to put it on a stand to get WOT setting. I just hook up my jumper box , also a cool way to see if you have a dead spot in your TPS. You can watch the voltage as you slowly go through throttle changes.
Yes you could start it I'm just that kind of guy that wants to be picky and hook a jumper up and do it without starting it. Thanks for the info guys!
