Talk you rear plastics, seat off and the metal shroud. On the turbo waste gate controller you can adjust the metal rod that attaches it to the waste gate. Shorten the rod and you increase boost. Lengthen the rod and decrease boost. I put my boost to the lowest setting 10psi and then am using a hallman rx pro boost controller(ran to the handle bars) to increase it up and down from 10 psi to 17 psi. This way you dont have to take the seat off everytime you want/need to increase boost.
I dont actually have it mounted directly to the handle bars, it is mounted on the front side of the risers. You can be riding it, turn it up and check it without having to stop. Just turn it up a little more check your boost gauge and keep trying, until you get the your desired boost level.
My MCX kit came with a external fuel pump and is mapped to around 18 psi(17.8).
Later kits did not come with the external fuel pump and are only mapped to 15psi. You would have to get a external fuel pump and the box remapped if you have the later released kit.
As i have learned about the turbo 4 stroke yamaha, I listened to a few guys on here and shortened the waste gate rod, thats a NO NO. If you do this you are reducing the amount the waste gate opens. You also build boost, but slow your exit of waste. So if you want more boost add a hallman boost control knob between the turbo snail and the waste gate actuator and that will let you run the amount of boost you want. I like the idea of being able to turn it way down in the even you need to borrow some pump gas to get out of the mountains from your buddy. JMO
