Where do you easily disconnect the ECM
Weld Center cooler in assembly. ECM connected
Well i welded up Center cooler from stud puuncture w/ Tig, in assembly w/ ECM connected.
Grounded out on cooler w/ C-clamp, and then started up,, no issue.
I would think that as long as you have a good ground that you would be fine, but disconnecting is always the better idea just to be safe.... As long as she's running good I think you did good:beer;
The guy that welded on mine said that as long as the ground is good, and the ground clamp is placed very close to where you are welding, there's no issue.
