Wouldn't Home Depot have it or Lowes? They can usually cut as well if you have measurements, I believe its just treated lumber that you need, at least that's what I put on mine...
P
Need to replace the deck on 12' open trailer, just need to find a local source for marine grade plywood. If I can get it at a place between Cheyenne and Longmont that would be ideal. If they can do the angle cut for my V-nose thats even better.
What is the major difference between marine and green pressure treated? At what cost? Im interested now...
Googled it, $58 for marine, $30 for pressure treated 1/2" 4x8. Almost double the price but which will last longer? Someone do a test.
If you have the Triton trailer they have a lifetime warranty on the deck. I just replaced mine with factory marine grade from Triton. Find your local dealer for Triton trailers.Need to replace the deck on 12' open trailer, just need to find a local source for marine grade plywood. If I can get it at a place between Cheyenne and Longmont that would be ideal. If they can do the angle cut for my V-nose thats even better.
Call the factory directly for questions.Even if it's a 97' and I'm not the original owner?
