Where can I buy replacement springs for old polaris?
SpencerA
I need a new rear spring for my wife 2 up Indy Trail deluxe 1990. Polaris dosn't carry them anymore so do you guys know any companies that would carry the replacements?
check slavage shops around you, or craigslist and ebay. otherwise HLSM I think carries that stuff..
for that sled I might actually look at getting a whole skid, if you find one cheap. that way you have some spare parts incase anything breaks.
What is HLSM? I would like to try to find a new one because most likely if I find another used skid its going to have the same problem considering its over 20yrs old.
Does anyone know are the 2up springs on that 90 Indy trail deluxe different then the springs on a 97 XLT Xtra 10? I have couple of skids laying around but I figured those springs are not as stiff considering their not 2 up skids. Finding those springs even used looks to be a lost cause. Any other suggestions?
checked out that website and they don't carry them anymore either. I might just try a Xtra 10 spring to see how it works. Mine sag so bad now that I can't imagine it would be much worse. I figure we don't ride 2 people usually on that sled so should be fine till I can find a replacement.
I may happen to have a set off springs from a 1989 supertrack which should be same configuration but of a larger wire diameter. Let me check and post what I find tomorrow evening. I'll also check and see if part numbers interchange.
