Where are the transfer ports?
Went to summerize the sled today. Pulled the plugs but could not locate the transfer port. Looking for a photo or description on how to locate that so I can get some fogging oil in and get the sled put away
Couldn't find holes in the cylinders for the life of me. Starting to think I'm crazy/blind
Is it on the same side of the motor where the exhaust manifold is or on the sides? I'm assuming the holes aren't plugged.
You will have to rotate the engine over slowly until the piston is as far down in its stroke as it will go.
Give me a red thumb for trying to help you out? Look harder bro. It's not like they forgot to machine them in your engine.
Yes they are on the sides.
And you might be crazy/blind, i wouldnt rule it out........
Look right where all boost ports are on every case reed inducted two stroke on the planet!!!!!!!!
