Whats wrong with this picture?
Is it the fact that your running a blue spring instead of the green/yellow you should be running?
What do I win???????:face-icon-small-blu:eek:
motor bogs but won't run?
I'm not 100% sure, but it appears that the words "Arctic Cat" are rubbed off on the belt. It is my understanding that the sled will no longer recognize the belt as something that should be there and subsequently will reject it (as can be seen in the video clip). I sugggest that you write "Arctic Cat" back on the belt and see how she runs. :beer;:beer;:beer;
What's the problem? Belt looks a little worn and might need replacing sometime in the future, don't rush it though. Look on the bright side, I don't see any molten aluminum dripping off the clutch sheave faces. I'd call it good and "Fly as is"...:face-icon-small-ton
Don't belts flip over inside the clutch when they are too long for that center to center?
You needed to give it a little more REP to take the heat !!
----- Gimpster -----
primary is really off kilter with the frame of the picture...recrop the picture square with the primary on your computer and your sled will be fine
change out that blue spring, Id say drop the $$$ and get a ti spring, should help out a bunch!
