What's the best pipe for M1200
Jaws are great, but...
I would check with D&D - they likely have a matched set to go with your big bore kit. Mixing aftermarket components can sometimes leave performance on the table, and result in a poor performing, finicky sled. Pipe outlet diameter plays a huge part in this, too small of an outlet can let heat "back up" into the combustion chamber and cause melting of the piston... If you are set on Jaws, call them and see if they have run thier twins on the D&D 1200 kit. My 2 cents - hope it helps.
