if you want a radio and a gps i would go with the rino 530hcx but for just a gps get a garmin 60csx with the 60csx you should not have a problem with losing signal
Or power it off your sled... most new GPSs can take 12V, which makes connecting it to a sled real easy.
I did that at first, and fried my first unit. If you don't have a battery on your machine,you need a voltage regulator. The power peaked and cooked mine. Luckily Garmin covered it.
Snowbunje makes a kit for 50 bucks
It was a rino 130.
It was good for about 2 trips, then all of a sudden it would just vibe and no screen .
I don't know much about electrical, but I was told that the stator on a doo generates AC and then gets inverted to DC. or the other way around..Not sure what screws it up, but it did.\
I was told by a few sources that you need something more than just hooking up to a couple of wires.
I have this link on making your own, perhaps someone can verify if it would work.
http://www.numbskull.com/snowmo/gps/schematic.asp
Also use lithium batteries. They last a LOT longer in the cold temps. Regular bateries ususally shutoff after 5-6 hours when it is -20.
Do you ever ride in inclement weather?Is it worth it?
Garmin hands down; Rhino, 60cs, ColoradoWhat are the good ones?
What should I look for in it?
