C
yes I am for a customer and we found a motor on ebay to replace it.
about all that is good is one cylinder the head and the stator/flywheel.
The inspection hole on the top of the case just above the flywheel is directly below the coolant reservoir overflow hose................. I've also seen a bolt fall in this hole and tear up all kinds of crap.
Might not be a bad idea to replace the stator as preventative maintenance, but more important...
Inspect the flywheel close, I've seen 3 now (05's) that have had the magnets come loose and wreck the stators. All 3 were very interesting back country retrieval missions.
Not sure about coolant issue but Have had rivet {from skidplate?} in stator.Would die everytime you laid it over until it died !!!! The holes definetley can let objects liquids in.
