I would not turbo your 2010... high compression then the 2009. Are you wanting a pump gas turbo or a race gas set up? boondocker has a nice setup minus their new ebc (electronic boost controller). put a lower compression head on your sled so you can get more boost. friend of mine has an 09 with boondocker setup and runs 8lbs flawless on pump gas. always runs consistent never messes with his numbers. no ebc. the turbo pipes arent worth the cash you lose to much lowend for a gain on top end. plus you gotta wrap that boondocker pipe to hold the heat. find someone to trade you your 2010 headfor an 09 head and then turbo it. remember the aero turbo is one big piece. if somethin breaksyou replace the whole thing. garrett turbo is nice cause you can take it apart.
