sjohns,
As stated, The PCV will work to fuel any turbo charged system utilizing fuel injection. All the PCV needs is a reference point for boost for the included TMAP sensors that the PCV will ship with.
Contrary to what's been mentioned - the PCV does NOT override/reflash/spoof the stock ECU. In this specific case on the Arctic Cat's, the PCV only plugs into the large 34-pin stock ECU connector and a ground lug. At this connector we obtain the power, injector, and the TPS signal that we need to fuel change the fuel delivery to the engine. The PCV does not intercept the i.e.: Air temp sensor to spoof different voltage readings - thus trimming the fuel. The Power Commander operates simply in pure PiggyBack form altering no signals returning back to the ECU.
The Arctic Cat's are perfect contestants to utilize our PCV-PTI system which automatically compensates for elevation changes as you ride. In fact, I was pleasantly surprised when tuning a Turbo system on an Arctic Cat sled, that our "Direct Pressure Compensation Feature" worked perfectly -- and required Zero tuning to the pressure table. By already adding the theoretical amount of fuel required, the AFR was spot on at all boost levels without inputting any numbers. This resulted in a very happy customer who's machine runs the same every time he pulls the cord at the parking lot, or on top of the mountain.
~T.J.
