Does it fit from a Polaris rmk 900 -06 with 159*15*2,4 track?
they vert escape should have came with that track. that said, if you remove the front cooler you can fit the 2.4, you will have to put a bigger rear cooler on it
If I remebmer right, you can get a 2 1/8 to fit without changing drivers and that is it. The 2" Camoplast 159 is a great track. If you move the suspension back 1" and add a bigwheel kit you can fit a 162 under it. My buddy did that with a new, at the time, 03 Vertical Escape and it worked very well. If you are going to start dumping money into an 800 edge, may I suggest an 07-08 700 CFI. My 700 (stock for stock) was leaps n bounds better than my 02 800.JMO
