Curious what tracks speeds I should be seeing. 13 xm 163 felker installed turbo and felker clutching. Running 22T top gear. Having problems with aerochargers boost springs. Running their 7 pound spring and added 3 shims but still only hitting about 6 pounds at 8k feet. Only seeing about 45-50 mph track speeds in deep powder. Flat rips on trail though but seems like everything gets hot really quick and rpm's fade in deep snow fast down to 7800ish. Felkers set up clutch and fueling for 7 pounds so been adjusting clickers and fueling to try and compensate for the low boost. Just not sure if the inconsistency is common or looking for some ideas from you all. Other thing is at 3800ft on a stand boost is just over 7 pounds. I realize there's no resistance on motor but almost a 2 pound boost drop at elevation seems high
