i have a 09 M8 and put the slp single pipe set up on with the black diamond air box, i have run with everything except turbos, even m1000 stock (actually beat it)
only issue i have is i go through belts quite often 4 last year, my 07m8 has the original still on it.
i heard the m1000 belt is something i should put on it, harder compound or something, anyone had these issues and know the cure?
the dealer checked the alignment and said it looks good, as i side note i thought maybe the heat was the ultimate factor so installed the 2cool air vents no differnce, i cant imagine i ride it to hard.....
any ideas?
also if anyone is running the same pipe and box did you do any clutching?
i left mine stock and it seems to be good, tried a couple different helix on the mountain and the stock set up seemed to pull harder and shift quite well, one complaint i would have it seems with the stock setup on a long pull it tries to pull like it is in 5th gear when it should be in fourth, but my rpm is still around 7800-8100 at this point....
feedback is welcome
what is the best performance parts to run on an 09 m8? what are you guys running and what works good together?![]()
A couple things going on here....WyoBoy, There is a big difference between the Pg M8 and a piped 1000. I know, I know...snowest says it isn't so but snowest doesn't always know. Remember that some of the people saying the BB with stomp a turbo make their living selling BB's and N/A sled products. They are very different and in very limited situations you may see a BB shine but turbo makers are selling a ton of turbos for a reason and its not because a BB kit that's half the price works better and makes more power. I don't want to start another pissing match but go ride them both and see for yourself.
As Far as turbo kits go, there are a lot of good choices. Twisted, Boondocker and CPC all make good kits. Most people will promote what they ride. ACMtnCat, I know the experience you guys had with hatchers kit last year was pretty rough but he also had an old kit without all of the updates that have been made in the last couple years. I agree, I wouldn't have had a BD kit from that era, but things have changed. There are a lot of people that had flawless Boondocker kits last year, many of those people are on the forum. I'm not taking anything from the Twisted or CPC kits, they both run well. I went with Boondocker because of their boxes and electronics, IMO they are superior to the Attitude box that both Twisted and CPC use. Run what you want and I'm sure what ever kit you chose you'll be impressed. FYI, there's a pretty good deal on a new CPC RG Kit in the swap.
