What spring for t nytro do you run?
was using the stock set as tight as it would go but the backshift sucked went to a artic cat red white and it was to stiff and kept hitting the revlimiter so went with the artic cat yellow works awesome
The cat green is the next step stiffer that the red/white. The green spring is the stiffest that cat makes. If you want stiffer than cat green you need an EPI purple or a Cutlers silver, they are about the same.
spring
for whos using the yellow cat spring what degrees is it at and what helixes are you guys running, the stock 39degree shifts up too slow for a turbo imo.
I tried the red/ white and it was not enoughf to back shift for me.I will try another one here soon and let you all no what works for me. 4 thru 5 k in elevation and 69 grams of weight ( super tips). shock wave secondary turned in 3/4 of the way.
