What ski stance and why
Was wondering what ski stance everyone runs on their revs? Holz sells a-arms for 41", zbros 43 & 45. Has anyone tried the timbersled a-arm/spindle set up? Thanks
depends
If you boondock narrow is usually the best, if you race..wider for stablity, hillclimbing jackson hole...mile wide, just look at the A/C HCR or the Doo hillclimb edition..so it all depends on what you like to do..the arsfx a arms are desinged for hillcross and jackson hole type racing..holz are lil bit narrower (42)and are acceptable for boondockin but i like it as narrow as it gets for layin it over which is why i like the stock width with my ski spacers on the inside
I have the TS Barkbusters on mine the feel good 39'' ski stance which i believe is the same as stock. I only changed because i bashed the stock ones on a rock. Either way im happy with the new ones
I'm with pistonbroke800, I also have the Timbersled front end on my mod rev. Not only is it light, but it also turns alot sharper. It might look wimpy at a glance, but when put on is actually a very strong set-up. Another plus is instead of bending an a-arm when you catch a carbide or even replacing the nun, the hime joint will give. They are usually avaliable from race car suppliers or your local parts/machine shops.
