what primary setup??
screech
what is the best clutch setup for the turbo xp?? i ran the stock clutches last year but looking at possibly a polaris primary... with everyones experiance, whats working the best for you guys? i know everyone is going to have different opinions but i need something better than the crappy setup i had last year. thanks!
:face-icon-small-dis
:face-icon-small-ton
clint, what kinda boost you gonna run, and what gearing and track you got.. gotta ask the right questions to get the right answers!!!
from what I have figured out most people are runnign 21 grams and a 160/320 spring, around a 45* helix and cant remember what secondary spring,
I am also interested in what people have to say about this, I will be running a tied on mine when I get my machine up and running
This is basically a long drawn out BUMP for your thread
clutching
IMO...If your running up high the xp likes a little less pin weight...saying 19 ish grams...415 ramps...a 160/320 is good in the primary and then throw a little more helix at the secondary...40/48 reverse angle is ideal. This set up keeps the bottom end nice and snappy. Drop you top gear down to a 19th.
good luck
clint.. get the right springs in it and i have a set of adjustable pin weights for tra's that im not using anything but the 18's out of.. so we can hook it up and test it good like
