The 14's aren't much different than the '12 or '13's, the motors are just dropped in any old way on the line it looks like. Well maybe the engines aren't 1/8" off just .050 now.
Totally agree that the main problem is misalignment under load, also agree jackshaft is weak bad design, and material heat treat.
Not a big fan of 2 roller secondary, would think that would want to pinch the center bushing more than a 3 roller? Wouldn't that center bushing bind easier with heat, grenade belts, or snap jackshafts?
Also seems the primary could use some work, feels like the low end torque of the turbo needs alot of mass to clamp belt in primary. Cat has not enough heel weight to grab on bottom of pulley near engagement. So they raised engagement, higher rpm with the light mass to help with more belt clamp.
Feels like it should have a 6 weight primary, 3 with a ton of heel weight to help hold belt on the bottom end, 3 others with mid to tip weight to take over the shift out.
No doubt the rubber inserts are super soft probably to eliminate any vibration, a person can put a little silicone in the gaps to stiffen it up but that would probably just make the heat exchanger leak quicker.
This is what I found out and did to the sled, which I believe is the main reason the belt is running cool on my sled, the extra vent and big fin ( more aluminum = larger heat sink) helps. After some miles I'll check it again and see where it ends up for alignment.
<table id="post9679041" class="tborder" align="center" border="0" cellpadding="6" cellspacing="0" width="100%"><tbody><tr valign="top"><td class="alt1" id="td_post_9679041" style="border-right: 1px solid #ffffff"> Sled has .7 miles on a track stand only.
First thing checked center to center. Pulled clutches used a 12" caliper and did the math came up with
11.593" too long for stock belt to sit above secondary clutch with proper belt deflection. That's how my '12 NA is and I believe most 1100's are
(you will see why farther down, there is a problem with the design of the Mag side engine bracket.
Decided to use Clutchweight's (
thank you for all of your great information it is appreciated by us all hoping to fix or improve our sleds) procedure to check the engine and jackshaft alignment. Checked secondary clutch runout on outside face of fixed sheave, less than .002.
For a target plate I had some stock that I made up for main cap straps for a olds, that I never used. It's hardened and surface ground flat and parallel, thats what I fastened to the crank.
Used a surface plate indicator inspection base with a dial indicator from the secondary clutch across to the crank.
Factory measurements were pretty poor.
Vertical parallelism: Zeroed at 12:00 position, then checked @ 6:00 position
-.050. PTO end tilted down. Excessive.
Horizontal parallelism: Zeroed at 3:00 position, and checked @ 9:00 position
+.030. PTO end tilted towards secondary ( opposite direction of what you want ).
Pulled sled apart to get to the PTO engine bracket, opened up the bolt holes and used a screw jack under the engine to try to align it.
I could not get horizontal parallelism any better than .008 tilted toward secondary clutch, by just adjusting the 1 engine bracket.
So I removed the muffler loosened up the 2 mounting bolts to the engine of the mag side engine bracket. Still I couldn't get the engine in Horizontal alignment, something was hitting.
There is a fitting coming from the mag cover that hits the engine bracket, so the engine can't physically move towards the secondary clutch any farther. It looks like just a flexable hose hitting, but it's not, the barb is right underneath. This can't be good for a hose either being pinched against sand cast aluminum.
I pulled the bracket out and cut it out for clearance and filed it so there was about a .25 radius in the corner. The heat exchanger should break before the mount goes IMO. That engine bracket 0708-574 hitting the engine mag case fitting was limiting the engine from moving back towards the jackshaft.
After getting things parallel, and about a day of work, center to center is now at 11.532. Probably could get it to 11.5 by loosening the front motor mount, but vert and horiz. parallelism miraculously came out to all zeros.
Didn't want to adjust any more, long day. But think I might have to add some rotation to the engine to take into account of jackshaft flex. Can't find any specs on the TCL parallelism, just the Z1 models. Either way it's better than .030 in the wrong direction.
Just a guess, but I'd have to believe that if this sled is made this way, it's just like all the rest that have been made. Mag case fitting hitting the motor mount, that is why most have long center to centers, and if checked I bet vertical and horizontal parallelism is way out also.
Everyone else should check their parallelism and center to center if you have a belt blower.
</td> </tr> <tr><td class="alt2" style="border: 1px solid #ffffff; border-top: 0px">
</td><td class="alt1" style="border: 1px solid #ffffff; border-left: 0px; border-top: 0px" align="right">
![](http://www.hardcoresledder.com/forums/images/hardcoresledder/buttons/xquote.gif.pagespeed.ic.9P-2bUYbWS.png)
</td></tr></tbody></table>
