SnowXTC Well-known member Lifetime Membership Jan 30, 2008 #1 What is this? We purchased this with a "lot" of parts and need to know what it is. Any ideas???
X xcsks Member Jan 30, 2008 #2 plate it looks like a removable windage plate off the back side of a secondary clutch. How big is it?
X x-guy ACCOUNT CLOSED Jan 30, 2008 #3 is it the rubber dohnut where the can exits protecting the skid plate from the exhaust heat?
SnowXTC Well-known member Lifetime Membership Jan 30, 2008 #4 It is about 10 inches OD, 8 inches ID, and a good 1/8 inch thick. Seems too thick for your typical windage and it would be a damn big exhaust!!
T tech a Free Member Jan 30, 2008 #5 It's obviously a chaincase porting template of some sort, not sure which sled it fits though
R richyrich Member Jan 30, 2008 #6 It looks like the rubber o-ring that is behind the fuel fitting on the new IQ sled gas tanks. Just made a new one.
C Caveman Free Member Jan 30, 2008 #7 Goes on the back of the primary clutch on a king cat I believe.
Rixster Well-known member Premium Member Jan 30, 2008 #8 Isnt that the new 3 7 9er exhuast bearing for the dragon?
M mountaincat68 Free Member Jan 30, 2008 #9 Caveman said: Goes on the back of the primary clutch on a king cat I believe. Click to expand... Thats it, balancer ring
T Track Poacher Free Member Jan 31, 2008 #13 You are all wrong, its the calibration spacer used to port the airbox. Seriously it is the balancer that goes on the backside of a primary clutch.
SnowXTC Well-known member Lifetime Membership Jan 31, 2008 #14 And how did you know that my airbox has been ported??? Chaincase is too. Not sure that would have worked as a template though. King Cat primary??? It seems a little large for that. What years?
X x-guy ACCOUNT CLOSED Jan 31, 2008 #15 maybe he threw in a part that has nothing to do with snowmobiles, just to screw with you
N NoSecondChances Free Member Jan 31, 2008 #17 Its a round piece of metal with some holes drilled in it. Appears to be steel. Hope that helps.
H hilinerider Free Member Jan 31, 2008 #18 whickerhooter doohickey thingamabob? high performance part!!
