After getting the TPS adjusted to the proper specs and the throttle cable loosely assembled onto the throttle body, I'm a little puzzled on how tight you should adjust the throttle cable to the throttle body? The confusion comes in where I thought the idle is adjusted by the idle adjustment screw and getting .93 Vdc from the the TPS..... If I have the throttle cable too tight to the point of opening the throttle plates further, would that change the idle? I'm sure it would, or was the throttle cable tension to the throttle body designed be adjusted just flush or with a little play (if so how much play). Any help in understanding this would be appreciated.
