what is the difference between Dragon, RMK, and Assault?
M
maddog21
different or same motor? all same but different body and etc? I heard no sway bar on Assault?
Difference between shock packages. Assault also has wider ski stance and different track. Track comes standard at 146" with shorter lugs. Assault is freestyle sled, so stiffer yet adjustable shocks. All bodies are the same. Sway bar is also on all sleds. Can be easily removed if need be. Not sure if Dragon motor is different, but don't believe so? Hope this helps:face-icon-small-coo
They are all the same base sled. The dragon has a better shock package over the standard rmk and some extra lightweight items on it. The assualt has a stiffer and more adjustable shock package over the dragon and a few lightweight items but a little more heavy duty compared to the dragon. The standard rmk comes 144,155 or 163. The dragon comes with 155 or 163. and the assualt comes with a 146. The assualt has the competition track on it that is made for heavy set up snow. All the models come with a sway bar. All the motors will be the same throughout all the models.
Hope this clears it up a little for you
