What is the best way to hold an extra gas can
I just put the mountain addiction rack on my rx1 mountain and it works great only takes 20 minutes to install. I went with the small rails with two 1.3 gallon jugs. They have all different jug colors to match your sled. I went with Black. I will try to get a picture of mine. Here is a link to the site I purchased mine from:
http://www.klymazzation.com/snowmob...ain-addiction-bungeeless-gas-rack-track-rack/
I had the Mnt. addictions on my apex, I did not like them, If you ride a bumpy trail hard with the gas tanks still full they would pop off..
I would recomend the craigerbuilt. They have a simple plate that you pull a t-handle to release the tank and you can run 2 of them 1 gas tank and a bag to carry the extra things you need.. Check them out..
I have mtn addictions on my nytro for a year and half now never had a problem with them popping off. I think it is the best light weight system going.
I built brackets for 2 two gallon cans and put them on the on the running boards, man those worked good, the bumps on the trail wouldn't affect them,you rally the trail and not ever worry about them.
