Don't know if this has been covered but, it seems like the 800's that have seized do it repeatidly, as did mine, and Polaris realy can't say (this is the problem) and it seems some ,not all are running a aftermarket pipe, and the ones running the pipe with a fuel controller last longer...sooooo IF (with the EPA restrictions) making the fuel map lean, and you throw in "maybe" some bad fuel, and a aftermarket pipe "maybe" leaning the fuel mix a bit and you are running right on the edge, and your voltage regulator has a hick-up that is intermitant. would that be enough to cause a problem "YES" . My theory is unless you stare at your head light or gauges 24/7 while riding you will not catch this glitch but it is enough to lean you down to scuff pistons. Now this is just my thoughts but if I was still running a d-8 I may look into it. Ride Safe...G
