P
purepolaris600
I am running a straight 48 helix. Just wanting to know if there is a better helix yo be used thanks
straight 48 is a pretty solid choice. Have done a few with 44-48 and 42-46 with good results as well for different track/rider setups. Nice thing is you can get the twin trax helix's for fairly good prices and switch them around and see which shift pattern suites your riding style best.I am running a straight 48 helix. Just wanting to know if there is a better helix yo be used thanks
90% 48 straight
How does that flat finish angle affect clutch weight? I would think it would require massive weights to keep it in check?46-32F
True, what secondary spring are you matching with that helix? We're trying to come up with a good setup this year and everyone seems stuck on that 46 to 50 degree finish for the turbo sleds. I would like to put a helix in there that doesn't seem to rely so much on a crazy stiff spring to hold the belt from slipping. We may have to look at this setup as well.75 gram weights for our elevation. Primary and secondary springs impact this choice also.
I'm not denying that in any way. I am always intrigued by clutching, would like to try as much as possible.Rule #1 - If TRS says it works, it will work. You can't half Azz it either, you have to go all the way.
I don't know how many years ago we started switching from Cat clutches to the Team. Bill Lofton said put in a 48. I searched high and low for one. Everyone told me I was nuts it won't work. Kind of looks like the norm now. I have never been a big fan of the reverse helix's. Seems like a bit of a band aid. Guys use them to cover up bad bottom end.
Would like to know also. planning on going up to about 1.90 for the season or at least try it.Has anyone had any luck gearing up the pros with chaincases? Thinking about doing this since last winter my sled didn't seem to lug at all. Thanks
