What height bar riser should I use?
Matte Murder
I am 6'4"(almost 6'5") and I have showchecked a 2012 Pro RMK 163. What size bar riser should I use? I was thinking 3.5". Do you guys have a brand preference too? Also, does anyone make an adjustable riser for the Pro that is durable and simple to adjust?
Thanks for the help,
Wade
I wouldn't get too carried away thinking you need to raise it up. I have Pro-Tapers on my 2010 IQ and at times they are almost too tall. These times are usually when you are in the trees or on a steep sidehill that you have to stop and start on, they want to tip you downhill too far. In one of the posts a while back, Chris Burandt was commenting about these bars being too high for him as well and I thought he must be joking, but after riding mine I can see his point. I'm 6'5" or so and I wouldn't want to go any higher than my setup is now.
I'm 6'-1" and love the stock ride height. I bought an Amp 2.5"(?) before I picked up my sled and after comparing it to my D8 with a few inches of aftermarket rise, I decided to ride it. It was the same height stock as my tall D8. Love it stock. You are a few inches taller than I am, so you may need a couple inches. The Amp is a sweet riser!
I think Burandt's set up on the IQ's was to remove the 1" spacer and use
the stock ProTapers. Pro's do not have the spacer so I think he uses a RSI set up to get it down.
How high can you raise your bars on a Pro RMK before you need to lengthen the throttle cable, brake line etc?
6'6", I rode a friends pro and in the steep and deep tree'd riding I would not go any higher, maybe a lower bar height. I have a m-series and a few year back tried a 5.5" could work the sled to save my arse, so I cut it down a inch at a time until I was back to stock ride height and put in an adjustable just so I could raise it up to beat the little bit of trail, but when riding the backcountry it is all the way down.
Burandt is a little man. Pay no mind to his set up.
I have 4" RSI's and it might be a little to much. 2" would be just right for me at 6'4". Stock Cables are fine
Burandt runs our 5" 2014 Aluminum Handlebar. It lowers the Pro a couple of inches and is a bit straighter. Snowest forum members get 10% off on our website. PM for discount code.
Thank you,
RSI
