As title states, what gauges are absolutley required for a 2010 Turbo Nytro XTX?
I would put afr at number 1. Boost is just a number, afr at 16 pounds boost will change from sled to sled. I would prefer to have the gauge that will tell me my engine is going lean. if you go lean turn down the boost, regardless of the boost number it needs to go lower if you are lean (or add more fuel).
that being said i have afr, boost, and water temp.
If I'm looking at this wrong feel free to disagree.
Boost,then A/F for temp and elevation changes,then coolant temp for low snow or warm days.It's nice to have guages with a record or memory mode, sometimes hard to read guages on a climb or WOT run.
Jeff
I think we need to remember every turbo or supercharger kit out there advertises "our kit makes this much HP at this many lbs. of boost" the kit manufacterer has already figured out fuel and clutching for elevation.That being said, yes an A/F gauge will help fine tune,and the tach will tell if you're getting or holding RPMs,but how would you know to add 2lbs or lose 3lbs if you don't even have a gauge for boost??? Don't buy a turbo and just hope that you're hitting max boost, without a gauge you don't know.
Jeff
Each to their own but I would say if you are lean running 18#'s boost, chances are you are going to be lean at 16#'s. I always choose to dial in my A/F by adding or decreasing fuel. I use my boost controller to adjust for RPM only. My weights are always fully loaded and I never mess with any of my other clutching. IMO boost is just a number, some days I make XYZ hp at 13#'s boost, some days it takes 17#'s boost. I look at my RPM as a measurement of the hp I am making. If I can pull 10800 rpm one day at 13#'s and 10800 the next at 17#'s, then IMO I am running similar hp.
I love the crisp air days when you are making power at lower boost. This is why i'm going to go to a water to air intercooler. I think having ice cold charge air will help maintain consistent hp levels at lower boost. The Boost-It boys noticed that on their sleds this year.
I can see that. But what about the day you are making 16 pounds of boost and the signal to your fuel regulator springs a leak and you are making 15-16 pounds boost but your fuel pressure is down 30 PSI from normal? You will be way lean possibly a blown motor...... I guess it depends on how you get the fuel too. Another scenario might be your piggy back controller craps out and you are on the stock fuel system.
Im not advocating that you dont need a boost gauge, just showing the importance of AFR too (IMO).
Alot of what if's in your statement based on conceivable failures,just don't know how you can relate it to a guesstimated 15-16 lbs boost without a boost gauge?The failures you state could occur at 8-18 lbs,not the gauges' fault.I agree A/F is important and I run a Koso X2 so I can monitor and record A/F,boost,and temp.
Jeff
P.S. good conversation
Is there any cheaper alternative to a Koso X2? Any place to find good used ones?
I don't know Spankey,the Koso came with everything except the 26mm coolant tee.When you price out seperate gauges,mount,sensors,wiring,and complexity of install,IMHO the Koso is hard to beat. As for the A/F vs. EGT question,the 5 wire Bosch A/F sensor is very sensitive and accurate.Not sure if anyone out there runs EGTs on boosted Nytros???
Jeff
I know some kits are non adjustable, however I think that if you have an adjustable kit you may want to be able to judge where you would set the dial. Pump gas is not race fuel which might be a factor in where you set your boost. Elevation and temp also come into play. My Nytro will run as low as 7-8 lbs at 5000 ft on a -5 C day. At 900 ft and -15 C it is not going to be much below 15 lbs boost turned as low as it will go. At 10 lbs I can run premium fuel with no problem. Some claim 15 to 17 lbs with head shims are ok nowadays with some of the new fuel systems... I still believe good fuel saves $$$ in the end and once I hit 12+ lbs I make sure the octane is 100 +. Presently I am in the ballpark of 15 - 16 lbs and run 100 octane fuel.
JMO
What's the benefit of afr over egt?
