What exhaust for 06 M7 works best?
biggdaddy
I have an 06 M7 that we mostly trail and boondock and a little bit of climbing would you recommend and does anypne have one for sale. I am looking for a ceramic coated I was told do not get a ceramic coated y pipe but a coated pipe and can. I want to stay with a single and do not want to go to a fuel controller if incan avoid it. I would really appriciate any help in this department. Thanks in advance. Jeff
M7 pipe
I ran 05 m7 for over 5000 miles with speedwerx pipe. You cannot go wrong with speedwerx, good look finding used one. The stock y pipe is fine on m7. I did not need fuel controller, but I ride at 10,000 and up. At this elevation plugs were right on the edge.
I have an 06 Crossfire 700 and I put a straightline performance pipe,ypipe and a sno stuff can with Vorce reeds and ported and polished only been able to ride across the back yard in the grass so far but wow huge diff. She rips.
I had a Bikeman single and a bikeman stock pipe mod on a couple M7's and a Speedwerx pipe on an F7, both very similar. If you ride below 5000 feet look into adding a y-pipe to the package, if you ride above that mark the stock y pipe is the best.
Aftermarket single pipes on the M7 make very little gains without some porting. I would look at a RKT head over a single pipe for a power upgrade. If you want to spend about 500 more than do the RKT porting with speedwerx pipe for a 10-15hp gain but pipe alone will only yield 4-5hp.
I have an 06 M7. HSP can, Intake, some cluthing, Just sent it in to get a speedwerx single and mill the stock hed 10,000 of an inch.I ride 6000' to 10000' mostly trees and boondocken some hills. How will this work together,they said i shouldnt need a box. What do you think? thanks for all the info love this site, you guys help out tons.
STILL WAITEN ON SNOW-ALL HAIL SNOW GODS.
Single Pipe and Silencers do very little, if anything for that seld, some cans have been known to loose power over stock, Get your secondary right, you can get a lot of gain from a dialed in clutch on this sled. If i had 400 to spend on pipe, I would in turn spend that money on a head, RKT works well.
