What comppresion Nytro
What is a 08 Nytro suposta have for compression?
Not the ratio the PSI.
Looking at getting a turbo sled and I want to check the compression before I buy it.
Thanks
Turbo sleds will vary greatly depending on how big of head shim is in the motor. The shim lowers effective compression quite a bit.
I think 5% might be a little tight but less than ten for sure.
Minimum 199 and maximum 227 at sea level. Be sure the variance between cylinders is not greater than 14 psi.
Thanks
