B
bustamove
so im sure you guys have seen my numerous posts... im just trying to cover my.. BUTT, this time. so i completely rebuilt my engine.. new everything...
went riding for about 20km then bam blew apart mag side cylinder.. skirt broke off as well not sure if that was the cause or happen cuz of something eles
i premixed yes.
i did use spi pistons is that the cause?
i also dinged that injector a bit... took the chance of running it... im getting them tested to see if it was running lean
checked carb boots- OK.
heard something about throttle bodies?
anything you guys got throw it at me... i want this to be the last time i put money into this motor... also i have having bad running problems after i went into reverse off the truck.
also can you get just the rod bearing for the big end?
i premixed yes.
