I've been running BWK's since '01 or '02 I think. My sled went from being a stationary object on my shop floor to rolling with a push on the back of the seat. The 2 wheel kit used to be great, roll up to a group and someone always used to comment on my lack of wheels. Small advantage while sidehilling I found, barely noticable on the sleds I've tested with. To be honest, better things to spend your money on that billet bling.
Hi-Rise seat is a MUST
151+ track and a take-off or used rear skid out of a Cat. Been the lightest skids for 5 years or so.
Loose the heat exchangers under the running boards and install some BetterBoards. Small u-cooler in the back. If ou have the std stock shocks, upgrading them wakes the sled up, as does a set of skis. I fell in love with the C&A Pros when I tried em. Didn't want any other ski on there. Bar riser and gut the hood.
Don't have to do all of that, but that's the simplest for the cheapest. MadMax Performance used(still does) make some good HP out of these things and the options really are endless. But the seat, riser, shocks, and skis help handling tremendously and save some weight(seat is bigtime, as is the rear skid) The track is definately needed. Sled will be a different animal with a new track. Just remember that gearing and clutching changes are part and parcel with the changes you make to the driveline.(track)
Search for "HAMMER" on here. The guy is a wealth of info and can get you the parts your after, whichever way you go.
