Wet sparks on a 2001 700mxz
H
Feb 13, 2011
132
22
18
40
Over here
What can be causing Wet spark plugs on a 2001 700 mxz ?
So much fuel on them after the motor is killed í have to remove them and clean to get the sled to start up again.
Ox
Snowest's Axe Murderer
1,530
611
NW Ohio
www.midwestproductionmachining.com
Could be bad needle and seat or jetting issue. does the sled run good when started?
2001 have round or flat slides?
I've never had bad seats on the flats, but on a Polaris with rounds, you could NEVER park downhill. Always seemed to be a Polaris specific issue too. A doo with the same mik's on it didn't have near the issues.
G
Dec 23, 2013
20
7
3
45
Puyallup, WA
Sounds like your needle and seat in the carbs is not seating correctly. It is probably slowly leaking fuel after you shut it down, causing a hot soak condition. I would be rebuilding the carbs.
