West Coast Sleds Light Weight Front Suspensions Now Available
W
West Coast Sleds Light Weight Front Suspensions Now Available 15% OFF ***
We have been hard at work since last spring on introducing our new line of light weight front snowmobile suspension products. Our kits are now available and ready to ship. The new ski stance is 39" center to center with + or - 1" width adjustment. The turning radius is increased by 10-12 degrees and the A-Arms are 4130 Chromoly Steel that are Tig Welded. The Spindles are 6061 T6 Billet C&C Machined Aluiminum. Most front suspensions uses all O.E.M. Bushings, sleeves,Bal Joints and tierods. Delrin bushings included in all other kits. Two new upper and lower rod ends and aluiminun spacers connect the spindle to the new A-Arms. The Polaris IQ kit eliminates the sway bar *Fox Float Shocks Reccomended For All Applications*. The left & right spindles along with upper A-Arms are interchangeable from left side to right side on the Yamaha kit. All kits save 8lbs-10lbs over the stock applications if running Fox Floats. All kit prices are raw steel or powdercoated finish. Polishing, Anodizing and Chrome finishes are available.
*All Kit Prices Are Free Freight To The Lower 48. $30.00 Freight To Alaska & Canada*
**15% Off If Order Placed By October 1st, 2009**
Yamaha Nytro $799.95 (Chrome not included)
Ski Doo Rev Chasis $799.95 (Anodized spindle not included)
Polaris IQ Dragon Sway Bar Delete $799.95 (Saves 5 lbs)
Arctic Cat M-Series $499.95
Inc. Chrome Moly A-Arms and Tie Rod Ends Save 6 lbs
Ski Doo XP $799.95 (Kits Available 10-1-09)
Inc. Billet C&N Spindle and Chrome Moly A-Arms
For More Info Contact Sean @ 559-841-6635
Were trying !
We have a lot of projects in the works. Also have a hard time locating a straight stock apex front to test? Anyone ?
Looks like timbersled barkbuster front end with billet spindle of same geometry to replace tubular welded unit.
Well....Your close, but made a few other changes to better our product. You will have to see and try these kits in person to truly appreciate there quality.
Thanks for your support...:beer;
I have an 07 dragon rmk. Send me a set for free so I can check them out. I will then test them all winter for ya at no charge;):beer;:beer;
Does look like a nice setup, good luck this season:D
I got the new A-Arms. They are AWESOME!!! They are at the powder coaters. Once they get back, I'll post some pictures on the mountain sled.
