I recently acquired a Marlon sled deck to use year round. It is mounted to the bed of a '17 F350 DRW. I picked this model to carry either a UTV on a riser, ATV on the deck or of course two sleds.
I am incredibly disappointed in how much water gets through the deck when it rains. I fortunately did not have anything in the bed that might be ruined by water. The sides, front and rear are of course not without gaps to let in some water so I wasn't expecting it to be completely water tight. I did not expect, however, to have the degree of water raining down between the aluminum decking. I discovered the problem after a decent overnight rain storm. To see for my self I used a hose with a wide spray pattern on the deck and saw just how easily the water comes through. No where is safe under the deck.
I enquired briefly how much hit would cost to line-x the deck. "Thousands" was the answer due to all the masking. Perhaps I can get them lower by partially disassembling removing all the plastics and glide trim so they don't have to mask so much. Still a ton of work and expense.
Perhaps I could seal from below or at least divert the water to the sides off of contents.
Any have experience with this sort of thing, Marlon in particular or another brand? A big sheet of plywood would have been better (and cheaper) at keeping out the elements.
Any suggestions would be appreciated (short of selling the damn thing). I'm too far down this expensive rabbit hole.
Thanks in advance!
-Law
Thanks in advance!
-Law
