Just wanted to let everyone know that we are open Tuesday through Saturday ,10-6pm this week. We have most Oem belts, oil and a ton of parts. With the dealer being closed we will try to help as much as we can!
We also extended our sled service until the first of the year....
One of the most complete service job you will find anywhere. This is a FULL service, not a inspection or look over. Why pay dealer pricing when you can save money and get better service! We can also hook you up with clutch kits, tracks swaps, suspension etc!
$399.00+parts/oil
Compression Check
Clutches removed, tore down,media blasted, inspected, clean, shimmed and aligned.
Chain case cover removed, chain/gears removed, inspected, cleaned and new oil.
Diamond drive serviced
Chassis greased
Ski alignment
Clean power valves
Adjust track
Check suspension
Carb sync
and much more...
We have training in almost all brands, raced professionally on the RMSHA hill climb circuit for over 7 years and have some of the fastest turbo sleds in the country. So if you need a service or custom tube chassis laying down 400hp we can take care of you!
$399.00+parts/oil
Compression Check
Chassis greased
Ski alignment
Clean power valves
Adjust track
Check suspension
Carb sync
and much more...
