WCS Yamaha Nytro Light Weight Suspension "Black"
W
Our kits are available and ready to ship. The ski stance is 39" center to center. The turning radius is increased by 10-12 degrees and the A-Arms are 4130 Chromoly Steel that are Tig Welded.
The Spindles are 6061 T6 Billet C&C Machined aluminum and anodized black. The front suspension uses all O.E.M. Bushings, sleeves and tie rods. Two new upper and lower rod ends and aluminum spacers connect the spindle to the new A-Arms.
This kit also alows you to eliminates the sway bar (Fox Float Shocks Recommended). The left & right spindles along with upper A-Arms are interchangeable from left side to right side. The kit save 8lbs-10lbs over the stock Yamaha Nytro front suspension. (Our kit weighs in at 15 lbs ! ) All kit prices are raw steel or powder coated. Colors: Black Suggested Betail $699.95
Color: Black Order Here ! http://westcoastsleds.com/cart/index.php?main_page=product_info&cPath=2_24&products_id=24
