water meth on nytro
Has anyone installed water meth injection on there none boosted Nytro? I can understand the benifits of using it on a boosted aplication. But stock? The dude at the (truck)performance shop claimed it would give me 70 hp on my old chev truck. An exageration i'm sure, but if it would give 10 hp to my nyto I might shell out the $450.00 bucks. and when I can afford boost I'll still have it.
On a stock sled there would be no measurable gains. The purpose of meth is to raise the octane of the fuel charge.....to eliminate or help eliminate detonation. Unless you are running high cylinder pressure (BOOST) or super high compression in a naturally aspirated configuration you would not benefit from this application.
X2. Wait until you are boosted, then go for it if it suits your situation.
im working on this right now.not sure why you feel it would not help a naturally aspirated motor?if you know something i dont know, id really like to hear before i spend too much time on this.
from what i have learned it should make any motor more efficient, which in turn will also create better fuel economy, more torque, and lower the octane needs of the motor.im pretty new to all of this ,so if there is some info. out there about why it wont work, please direct me.im even trying to design one for a 2 stroke. amp draws are my biggest issue so far....
i may be off topic here (stumbled across this thread)
isnt water meth inj. more or less the same thing as brown gas???
brown gas applications are what im working on, i may have just misunderstood the original thread, if thats the case...sorry
water meth injection is primarily for cooling the cumbustion chamber increasing octane , depending on the mix you can gain performance as will due to the meth itself. how ever as has been stated, its for high compression, boost, so I don,t know that you will see the gains with a stock motor due to the fact that the cooling affect may actually hurt you. due to the lack of compression and need for more octan. kind of like running race fuel with low compression it doesn,t work its too cold for proper combustion.
add some timing & compression & it will work wonders & make some good power.it is for lowering cylinder temps,cooling your air charge & eliminating deto.:beer;
