B
bboll
I have a question about the waste on a 700 Dragon. I'm trying to turn the boost down as low as it goes with the orginal wastegate spring in order to do some MN testing before I head west. I know that I may have to buy the low altitude spring, is it hard to change?
1. I'm I correct that the boost controller is only the 'fine' adjustement and the rod on the wastegate is the main boost adjustment?
2. How do I adjust the boost on the wastegate?
3. Which way would I turn in the rod on the wastgate to reduce the boost?
4. Is there a rule on the number of turns on the rod and boost controller per lbs of boost?
thanks in advance!
thanks in advance!
