Washer in front axys
J
Jona$
Whats the thickness etc on the washers that goes between the bearings aswell the a-arms and spindle. Believe the nr is
9 and need 8pieces aswell the bolt nr 16 need 2.
The reason is im going with another local made front that usrs theese orginal parts and alt impact i had didnt.
Would love to get them in metric since im Swedish.
See i only need 2 for the shim of spindles, appreciated if any one knows.
1 mm thickness.
They do go on the bolt above and below the spindle surfaces that the ball joint goes between.
(If that makes sense)
The thickness shouldn’t matter then.
