Walker Evans
M
Sep 4, 2019
9
-1
1
just picked up a set of walker evans to replace the base ride fx shocks on my 14' standard rmk and they seem to be shorter by almost an inch. Should i be concerned about this? they came off a 16' axys. do i need to replace the shafts? or just run it?
MTsled3
728
694
93
Belgrade, Montana
The base RMK used the steel a-arms still after the Pro model switched to aluminum so your shocks are actually a little longer than the 2013+ Pro-RMK and Axys sleds with aluminum arms. They'd probably work in a pinch but I'd take the opportunity to upgrade to a 36" front end if you can afford it, i think all of them work with the shorter 2013+ shocks length. My brand of choice was Alternative Impact because of the sacrificial rod ends that save the arm in the event of a good ski hit.
05rmksteve
2,486
1,631
Brainerd, MN
I'll have to go find them and measure them.
On the 11 and 12 pros I would use 13 on up pro rmk shocks with a 36" a arms.
Sent from my SM-G965U using Tapatalk
M
Sep 4, 2019
9
-1
1
Well if you’re interested in trading I think I tried PMing you but not sure if I did it right. New to the forums
