w/c 1200 motor kit new parts 2300.00
1
1200psi
i have a engine kit ready to ship. THis kit has a new crank case all machine work done to case, head 12-13-14/1 what ever dome you want mag housing , flywheel hub and water rail, and pulley for water pump . This is all the hard parts and machined stuff now you just need to put it together with your parts. 2300.00
Brad
need head cover for w/c motor
I have a 1050 water craft motor with 700 power valve polaris 700 twin motor cylinders. woundering if you know of someone that makes a head or cover head to fit the tree cylinders that will not leak anti freeze.
Thanks
Tim
Power addiction scam
If anyone out there is looking for these parts beware that brad will be more than happy to take your money but you wont get what was expected i know this cause he still owes me 1500.00 from a p.o.s. 1200 motor that he built and tuned!!!! Oh yea he thinks i forgot about this well i will be seeing him before long!!!!!!!!!!!!! To collect
good luck on that the only problem with your **** is your self jackazz i dont owe you ****t It is pretty apperant that you ask anyone on here but your self and know one has had any Problems other than your self including the guy i sold YOUR motor to. MY famous falosify is and engine can only be as good as its tunner and i am going to leave it at that .
LMAO...Brad's stuff runs hard...leave the sour grapes in the trash...
Is this dude for real?
wow, cant beleive that guy is tryin to give you a bad reputation on probably the most reliable motor iv seen or heard of. you should turn his bars red for sure. it even makes me question buying your stuff even though you are the only one id consider. that guy is an idiot.
I've met this clown Jackazz and man does he live up to his name. If you ever want a laugh just turn him loose with a tool....he could screw up a handlebar hook! He has no business with a mod. Should be an Elan rider.
Brad's a stand up guy and sells a VERY good product. It's a shame to see this happen. I'd love a Power Addiction 1200!
All the parts iv bought from brad are top notch. You can call him anytime and he will walk you through anything you need to know.
Brads the real deal
adam
Brad is a stand up guy and has gone above and beyond to help. Buy with confidence and dont mind this round mouth.
A Custom Motor of any kind.
The funny thing about these 1050/1200 WC motors,
Many people want them, and 99% of the time the people just don't want to pay what it takes to get one COMPLETE!! And tested and set-up.
Then there are the Pipes, Most people cannot understand the complexity and cost to build a set that works for their application and RPM range the motor should be run in. THEN!!!! They have to be fit into the chassis without destroying the tuning of them.
Jackazz...........I don't know your story, But answer a few questions for me.
#1 - how much did you pay for your 1200 ???
#2 - How much did you pay for your pipes ??
#3 - Who fit them to the chassis ???????????
#4 - once your project was complete, did you take it back to the engine builder and pay full shop rate to haveit dialed in ?????
A complete 1200 WC is $8000.00 without pipes.
A complete set of unfit pipes are about $1000.00
Expert pipe fitting dependng on chassis style is about $1000.00
Ok thats $10,000.00
And that price is an over the counter hand off.
1 - You have to install it in the sled and make it fit and get the clutches lined up at the very minimum.
Then after all that, its your job to ----
2 - get the timing set right
3 - Clutches set-up
4 - and the carbs tuned.
( 5 ) - And most important, after its all complete..... did you take it back to the engine builder and pay him full shop rate to do a final dial in ???
If you yourself did any of the last 4 steps to your sled.... Did you also do step ( 5 )
Step ( 5 ) cost - If everythng you did was close to perfect your sled will need about $1000.00 worth of tuning by someone that knows what they are doing.
So if my math iscorrect -
Motor ----- $8000.00
Pipes ------$2000.00
Final tune- $1000.00
Total _____$11,000.00 absolute bare minimum.
Jackazz..........If you have paid 1 cent under $11,000.00 for your motor & Pipes ONLY to Brad then you have not paid what it costs to get it done complete.
If the crankshaft went around in a circle and the pistons went up and down and everything fit properly........... THEN YOU GOT WHAT YOU YOU BOUGHT PLAIN AND SIMPLE.
And If you paid 1 cent under $11,000.00 then all your problems are your own to sort out.
The bottom line.........Without trying to sound to bitter, Once you make a gesture to short cut the budget of what it costs to build a WC 1200 all the problems that come along the way are yours to fight thru on your own.
I don't blame anyone for trying to build one cheap, But if you make this choice be ready for a
sh!t load of problems. And its very possible you will have a 1200 that never reaches its full power potential because you didn't pay what it truely takes to get the max power out of your package.
Most people under estimate the cost and the complexity to bring one of these monsters to full power.
Jackazz..........I Have come to know Brad well enough to know you are rowing your boat with 1 paddle, and if you sense you are traveling in a circular motion you might have forgot something on top your lugage rack.
Think before you post.
Dan
Dan that is the coolest post i have seen in along time. IF jackazz post back then we will discuss the prices he paid.
Brads sano stuff
Brads 1200 engine parts look sick, fit perfect and run flawless.
He knows the 1200 front to back and always answers his phone.
His IQ billet drop spindles are like little trophy's you mount on your sled AND they make it handle better?
The pass through cooler he built me fit perfect and is a work of modern art.
His billet and aluminum metal work is bar none.
Everything I have bought from Brad is underpriced and over kill.
The jackazz must be a jack *** cuz that's just not Brad.
