OK 2006 800 Summit. The last day of our trip the sled ran like crap after I turned on the hand warmers,turned them back off ran great. So I replaced the accessories relay no change,then tried a friends voltage regulator still no change.
The voltage readings I get are all taken at 2500 rpm 13.3 lowbeam on, 12.0 highbeam on, and 8.1 with highbeam and handwarmers on. The tac. will drop to 0 and the lights on gauge blink with the beep beep in between turning from low to highbeams and vis versa.
I also took voltage readings from stator at the plug befor the regulator. The readings were 3.1 vac on all three phases, book says 3.6 vac between phases. All phases were .2 to.3 ohms book says 0 to .5 ohms.
Well any ideas on what the problem could be? Weak stator, or do I have another load on the system? Thanks Nick
