Voltage/gauge issues
I recently installed a boon docker turbo on my 14 pro rmk and installed innovate motorsports A/F ratio gauge and boost gauge and powered them through the accessory plug using a factory pig tail. I went to calibrate the gauges and after a couple minutes of running the gauges quit working, tested the supply and had power to them, So i called innovate and they said i fried the gauges because the voltage on snowmobiles aren't consistent enough for their gauges are sensitive electronics and they say i need to install a voltage regulator? Does anybody have a suggestion for a regulator?
I'd suggest installing a battery to run the turbo stuff. But first check the 2 amp fuse by the Ecm to make sure you didn't blow it
Sent from my galaxy note3 via tapatalk
